How to printer with dual extruders
Before reading this text,please make sure you have already read the set up guide of the version of 13B single extruder and you can use it to print 3D models. If not, please learn how to operate the single extruder. Of course, you can take this one as the single extruder version to start.
Step 1
Open Repetier Host,click Config/Printer Settings to set up the connection.
1. Name your printer.
2. Select the corresponding COM port and baud rate. Baud rate is generally 115200 or250000.
Step 2
Set up your extruder
1.Choose the number of extruder, here we choose 2.
2.Set up the diameter and color of filament
3.Offset X/Y refers to the distance between the two extruders,which can be adjusted based on real situations. You can leave it alone now.
Step 3
Set up the shape of printer
Home X: min Home Y: min Home Z: min
Print height: 150
Step 4
Manual control
1. X home
2. Check Y axis and Z axis respectively in the same way==
Step 5
leveling the two extruders.
Leveling the two extruder is very important if you want to printer with two extruders at the same time.
you may need to adjust again and again at this step to get both extruders in Parallel to heat-bed and with equal distance.
But it doesn’t matter, once you level them, you wont bother to adjust it later.
The settings mentioned above are set on Repetier Host,which only involves the control of 3D printer and the preview of model.
Step 6
If the printer goes well. We can go on with the slicing. First let’s get a quick view of the slicer.
Next, download the file: two_color_cube.zip, unzip the file and put it somewhere, you will need it later.
Step 7
Click Configuration,open Slic3r
Step 8
We have prepared a set of parameters for I3B_2E dual extruder, that is, I3B_2E_config_bundle.ini. You need import those parameters to software slic3r from here.
In Slic3r, under file> Load Config Bundle.. navigate to the folder we just downloaded and unziped, open I3B_2E_config_bundle.ini,
Step 9
After loading, you can find the option of Geeetech_I3B_2E in the drop-down manual.
Step 10
Unzip two_color_cube.zip,click Load to import the .stl files,choose two_color_cube_1.stl and two_color_cube_2.stl respectively.
Step 11: Slice
Step 12: you can print direct via serial port (USB connector)or save the G-code to SD card, and print stand-alone.
Step 13': The end
