GT2560
GT2560 is a compact board that is integrated with the mighty function of the Arduino Mega2560+Ultimaker and Arduino Mega2560+ramps 1.4 on respect of both software and hardware and has more premium features: the streamlined interfaces effectively avoid the unnecessary troubles, well-regulated compaction of components highly integrated saves more space and easier to be mounted on most applications.
5 stepper motors, swappable driving modules, mighty ATmega2560 processor with 256k memory, 16MHz operating frequency, high-performance USB serial converter FT232RQ, all these make the GT2560 an ideal option for a 3D printer control board. What’s more, GT2560 can run over 12V to 24V which gives higher torque and higher rotation rate.
(front and back images)
Hardware resources:
12V/24V 15A and 12V/24V 10A power supply
3 input for12V cooling fan
1 PWM output
Weight: 80 g
Software Resources
Firmware: Marlin
Host software:printrun Repetier-Host
Source
Interface specifications
1.DC IN: 12V 12A and 12V 5A
2.HOT_BED: heat bed
5.LCD ENCODER: LCD panel
6.SD Card
The subdivision of stepper motor can be setup by dial switch, turn on all the dial switch, as the arrow shows
Software setting
File Burning
firmware, as shown below.
Get Started
#define BAUDRATE 250000
#define MOTHERBOARD 7
#define EXTRUDE_MINTEMP 170
- At most 2 extruders, GT2560 supports 5 A4988 stepper motor drivers, they are X/Y/Z axis and 3 extruders.
2. What is the Power Requirement of GT2560?
- It is 12V 12A for the heatbed and 12V 5A for the logical part.
How to get
Visit here now!
