Delta Rostock mini G2 Building Instruction
Preparation
Chapter1 Base Assembly
Motor end assembly
Mount the LCD panel
Mount the fan
Mount the control board.
The directions of the spacer are as the arrow showing.
Mount the print bed.
Chapter 2 Top Plate Assembly
endstop mount
Drive wheel mount
Mount the extruder
The screws are bottom - up.
Note: If your are assembly the G2s, you will need another 4 M5 x 16 screws and 4 washers to mount another the extruder.
Mount the spool holder
Screw up the spool holder panel on the top plate separately with M3X16 screw and M3 nut and washer.
Through the spool holder rod into the panel, or you can do it later after you finish the building.
Chapter3 mount the smooth rods
Assemble the spider
Step1. Insert the hotend into the half bracket, stack the hotend bracket and half bracket together, screw up with 4 M3 x 16 screws and M3 nut.
(Note: For your convenience, the hotend is assembled with heaters and sensors, so, please ignore the difference in the picture)
If you are building G2s, the steps are the same.
Step2. Screw the fan onto the fan mount with 2 M3x 20 screws.
Assemble the auto-leveling probe
Assemble the diagonal rods.
Step2. Repeat the above steps for the other diagonal rods. And mount another end of the diagonal rods to the spider.
The directions should be as shown in the following picture.
Chapter5 Mount the Belt
*The belt should be neither too tight nor too loose, you can slide the carriage up and down to see if it is.
Chapter6 Connect the PTFE tube.
* If you need to pull the tube out, please press the blue part while pulling.
Chapter7 Wiring
4) Connect extruder
Step4. Connect heating wires.
Step6. Connect wires for Fan.
As shown in the red box.
Chapter8 Tidy out the wires
