Delta Rostock mini G2 Building Instruction
Preparation
Chapter1 Base Assembly
Motor end assembly
Mount the LCD panel
Mount the fan
Mount the control board.
The directions of the spacer are as the arrow showing.
Mount the print bed.
Chapter 2 Top Plate Assembly
endstop mount
Drive wheel mount
