Sanguinololu
1.support multiple communication configurations :
3.Adapts Atmel's ATmega1284 drop-in compatible. Currently, we use 1284P, the bootloader has been burned before shipping, and users can put it into use after burning the programming code.
size:100mm x 60mm
weight:73g
Software Resources
Firmware: Marlin
PC Software:
Sanguinololu driver for windows (32bit/64bit)
Interface specifications
- 2 ADC interfaces for thermometry: one for extruder and another for hotbed.
- 3 PWM to control extruder, hotbed and fan.
- 3 end stops for x/y/z axis( mechanical, optical or hall sensor)
Jumper Instruction
File Burning
Windows users need install driver before uploading. The board: Tools > Board > sanguino W/ATmega1284P 16mhz, as shown below.
Click the check“
” button to check if it is right and then click the “
” button to upload firmware, as shown below.
Software Setting
Arduino IDE Installation
Move the file sanguine into Arduino> hardware, reopen IDE.
Get Started
#define BAUDRATE 250000
#define MOTHERBOARD 62
#define EXTRUDE_MINTEMP 170
FAQS
file
Media:Sanguino-0101r1.zip Arduino 1.0.1 for Mac
