Acrylic Prusa I3 build instruction(8mm)
Notice:
Unfold and check the package
Tips:
Assemble the rods of a Y axis
| Required parts | Required number | Part ID |
Assemble the Y idler
Mount the Y motor
Build the printing platform
Step4. Mount the belt.
Assemble Y - Z axis
Mount the fan
Screw up the X-Z frame and the side panel then connect the rear part of the Y axis and the side panel together. You may need to adjust the distance of the X-Z frame to the rear plate.
Screw up the acrylic plates with M3 x 16 screws and M3 square nuts.
Assemble the 2 Z motors
Step2. Screw up the motors with M3 x 12 screws.
Assemble the X-Axis Idler
Put the screw through the printed Y idler piece, with the 624ZZ bearings in between. Lock the other end of a M3 nut.
Mount the assembled idler into the X-axis end. Lock it up with a wing nut. Here, you can insert the linear bearing into the end.
Insert a linear bearing into the other end of X-axis.
Thread the two rods into the two X-axis ends and then mount the brass nut under both ends.
Thread the zip-tie through the extruder bracket
Step1. Mount the X-axis belt bracket on the smooth rods. As you can see from the picture, the two linear bearings should be placed into the two slot of the bracket. Tie them up with zip ties.
Mount the extruder support
1.Put the 2 M4 nut into the hole, as shown in the picture.
2. Screw up the belt bracket and the extruder support with two M4 x 16screws.
Mount the extruder
This is the fully assembled MK8 extruder in the package.
Mount the aluminum plate under the extruder.
Then mount the assembled extruder on the extruder support. Use 2 M4 x 12 screws to fix. (the blue extruder support)
Mount the X-axis motor
Amount the X-axis belt
Thread the belt through the motor end. The belt is attached on the pulley.
Another end of the belt should be threaded through the belt holder on the right end of the X-axis.
Assemble the X-Z axis
Mount the end stops
Step 1.End stop of X-axis
Step2. End stop of Y-axis
Step3. End stop of Z-axis
Mount the LCD panel frame
Mount the filament spool
Mount the PSU
Mount the PSU on the right side panel with 3 M3 x 10 screws.
Example 1: Sanguinololu
Example 2: Ramps 1.4
Wiring
3.Connect the heatbed.
4.Connect the extruder
5.Connect the end stops.
6.Connect the power supply.
