Acrylic Prusa Mendel I3
http://www.geeetech.com/wiki/index.php/Tutorials This acrylic frame Prusa Mendel I3 3D printer is designed and manufactured by Shenzhen Getech Co., Ltd based on Reprap pursa I3, Geeetech I3 features simple assembly, easy debugging and more stable performance. The acrylic structure makes the printer less complex and easy to operate.As you can see from the above pictures, we provide two Acrylic I3, black one and tranparant one.
Main improvements and features
1.Simplified structure means fast assembly and easy adjustment, which saves you both time and energy as well as speed up the molding of your innovative products and ideas.
It usually takes up to 3 days for a DIYer to assemble the previous I3, not to mention the post-adjustment and debugging work. As to this I3 of Acrylic Frame, however, you can save 70% time.
2.Enhanced stability and reliability settle your fears about the performance of the machine from time to time, just feel free to print.
3.The power supply is assembled together with the printer; all the cables and wires are re-arranged to make it more neat and easy to asse mble.
We recommend the following practice instructions for the safe and effective use of our printers. Failure to follow these practice instructions may (i) degrade your printer’s performance, (ii) cause injury and/or damage, and (iii) disqualify you from customer support. Please ensure that you have read and understand all practice instructions before using your Prusa I3 printer for the first time. You can contact the Prusa I3 Customer Support Team with any questions about the practice instructions at our [forum].
Operation
- Never reach inside your Prusa I3 printer when it is turned on. Moving parts can cut or pinch you, and several parts reach high temperatures that can cause burns and other injuries.
- Always allow your Prusa I3 printer to cool down for at least 5 minutes before you touch any internal part or remove a printed object.
- Never leave your Prusa I3 printer unattended while printing or powered on.
- Always turn off your Prusa I3 printer and disconnect it from your computer when not in use.
- Never attempt to print using any materials that have not been approved by Prusa I3.
- Never operate your Prusa I3 printer if it appears damaged.
- In case of an emergency or malfunction, immediately disconnect your Prusa I3 printer from the power outlet and computer.
Placement
- Always operate your Prusa I3 printer in an open, well-ventilated area to allow potentially irritating fumes to dissipate.
- Never operate your Prusa I3 printer outdoors, near open windows, or anywhere where it may be exposed to water or moisture.
- Always place your Prusa I3 printer on a flat and sturdy surface to avoid power interruptions and deformities in your prints.
- Never place objects on or above your Prusa I3 printer or power supply.
- Always have a working fire and smoke alarm in the same room as your Prusa I3 printer.
- Never place your Prusa I3 printer near open flames, heat sources, or flammable materials.
Connectivity
- Plug your computer and Prusa I3 printer into the same power outlet for best performance.
- We recommend plugging your Prusa I3 printer into a surge protector with a circuit breaker.
- Only use the power supply that was provided with your Prusa I3 printer.
- Do not plug your Prusa I3 printer into the same outlet as power hungry devices such as air conditioners, space heaters, or other large appliances.
Modifications
Prusa I3 printers are tested for performance and safety before they leave the factory. Prusa I3 cannot guarantee the performance or safety of printers that have been modified by users.
- Prusa I3 PRINTERS CONTAIN HEATED MOVING PARTS. NEVER REACH INSIDE THE PRINTER WHILE IT IS IN OPERATION OR BEFORE IT HAS COOLED DOWN.
- NEVER LEAVE YOUR Prusa I3 PRINTER UNATTENDED WHILE POWERED ON OR PRINTING.
- DISCONNECT YOUR Prusa I3 PRINTER FROM THE POWER SUPPLY AND COMPUTER WHEN NOT IN USE.
- DO NOT ATTEMPT TO PRINT MATERIALS NOT APPROVED BY Prusa I3.
- ONLY OPERATE YOUR Prusa I3 PRINTER IN A WELL-VENTILATED SPACE AWAY FROM MOISTURE AND HEAT SOURCES WITH A WORKING SMOKE/FIRE ALARM.
Install the drivers
Windows 8
Windows Manual Install
How To Connect
1. Plug the USB port into your Prusa I3 and the other end into your computer.
4,Select GEEEtech PI3A in “Printer”
6. Hit "connect" in the upper left-hand corner, select GEEEtech PI3A. You should see the details of the connection in the console window in the bottom section of the screen.
7. Once full heat has been achieved do a few quick tests. Hit the X+/X- arrows to ensure that movement is possible.
Assembly
assembly manual for you to refer to. (pdf)
assembly manual for the new 8mm one
Leveling The Print Bed
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
FAQs & SOLUTIONs
