Assemble Manual of Geeetech Acrylic Prusa I3 (5mm)
Prologue Note: This manual only applies to the 5-mm acrylic Prusa I3. We have another one that is 8-mm.
As picture is much more helpful than words in assembly manual, so I use plenty of pictures and less word.
1.1Assemble the rods of a Y axis
| Required parts | Part ID |
Step1. Assemble the threaded rod
- Thread the nuts and washers on the two M10 threaded rods separately. The order should be:
- M10 washer > M8 spring washer M10 screw > M10 screw > M10 washer > >A 12> M10 washer > M8 spring washer > M10 screw > M10 screw > M8 spring washer > M10 washer
Step2. Assemble the Y axis smooth rod
- Slide 2 bearings on each smooth rod. Before you slide the bearings please make sure they are clean. (Ignore the black one in between)
Assemble the Y idler
Step1. put the M4 X 25 screw into the end of the Y idler, from outside to inside, and screw it up with a M4 nut.
Step2. Put the screw through the printed Y idler piece, with the 624ZZ bearings in between. Lock the other end of a M3 nut.
Step2. Mount the assembled idler onto the front support plates.
Mount the Y motor
build the printing platform
Step1. Mount the belt mount on the bottom side of the plate.
Step2. Get the build platform plate zip-tied to the 4 linear bearings.
Step3. Attach he heated bed.
The circled part need soldering.
Assemble Y - Z axis
The main frame is held upright after the acrylic fender washers on the Y axis threaded rods. The front of the plate should be sticking out a lot further than the back.
Mount the rear part of the Y axis and the side panel together.
Step1. Assemble the Z-axis bottom mounts
Assemble the 2 Z motors
Mount the fan on the left side
5Assemble the X axis (the horizontal axis)
File:Prusal I3 manual pic41.jpg
Step1. Assemble the X-Axis Idler
Step2. Mount the idler into the following part
Step3. Assemble the 2 smooth rods.(380 mm)
- Slide 2 bearings on the each rod as shown in the picture.
Slide the X-axis motor-end and the idler-end onto both ends of the smooth rods. The X-axis motor-end is on the left and the idler-end on the right. This is going to take some force, or you can use file to make the holes lager.
Mount the brass nut on the following part.
Insert the rest bearings into the bracket of both end of the smooth rod.
Thread the threaded rod through the following part. It would be easier to do it now.
Mount the aluminum plate under the extruder.
Fix the two pulleys on both if the threaded rod. And plug it on the motor shaft.
Assemble the X-Z axis.
Step1. thread the X-axis through the Z axis.
Step2 assemble the top mount of the Z-axis.
step1. Thread the zip-tie through the extruder bracket.
Step2. Mount the extruder bracket on the smooth rod and insert the two bearings into the bracket. Tie up the Y belt then.
Step3. Amount the extruder support.
Step4. Mount the extruder
This is the fully assembled MK8 extruder.
Fix the assembled extruder on the blue part. Pay attention to the direction of the motor and the fan.
Pay attention to the exit of the red wire, it will affect the final wiring steps.
Mount the X-axis motor
Assemble the belt.
Pay attention to the tooth mesh of the belt and the part in red circle.
Mount the end stops
End stop of X-axis
End stop of Y-axis
Note the direction of the switch.
End stop of Z-axis
Mount the LCD panel frame
Mount the filament spool
So far, the framework of the 3D printer is almost finished.
mount the control board on the left side panel
Ramps 1.4 + Mega 2560 + A4988
Stack the Ramps 1.4on the Mega 2560 and plug the 5 A4988 on the Ramps 1.4.
Sanguinololu
Plug the 5 A4988 on Sanguinololu
Mount the PSU on the right side panel
Pay attention to the switch on the right side of the PSU, there are two options of voltage: 110 V and 220V, choose according the standard in your country.
Wiring
PSU wiring
Do make sure you connect the wires correctly, otherwise it may lead to damage to the control board and the PSU.
control board wiring
1)The referring wiring schematic diagram of Ramps 1.4
2) The referring wiring schematic diagram of Sanguinololu
Next is the testing and debugging.
