Brainwave
Brainwave, derived from sanguinololu, is control board for reprap 3D printer with low cost and high capacity-price ratio in that it is powerful to drive a printer of single-screw extruder by providing only the minimum required components. Such as a printer with single extruder and 2 Z axis or the delta style printer.
- 12v power input
- standard micro USB connector
- The entire interfaces are at the edge of the board, making it possible to fit vertical or right-angle connectors.
- Adopt Atmel AT90USB646 microcontroller, with USB- RS232.
- The steps of stepper motor can be divided into 1, 2, 16, and 32. The maximum power output can reach to 800MA
- 2 connectors for Z axis
- Optional motor power output of each axis
- Heated bed supports separate power input from the logic part (up to 24V 15A)
- Integrated heater/thermistor/stepper connector for E channel
- controllable fan
Overview and Hardware Resource
weight:81g
Software Resources
Pc software:
Interface specifications
2 ADC interfaces for thermometry: one for extruder and another for hotbed.
3 PWM to control extruder, hotbed and fan.
3 end stops for x/y/z axis( mechanical)
Jumper Instruction
Boot jumper cap: do remember to put the jumper cap, or it will affect the connection with PC and the upload of firmware
File Burning
Windows users need install driver before uploading. The board: Tools > Board > [CDC]teensylu/ Printrboard, as shown below.
Configuring serial interface: Tools > Serial Port > the corresponding COM Port of Brainwaveis usually the last one. As shown below
Click the “check ( )” button to check if it is right and then click the “ ” button to upload firmware, as shown below.
Upon uploading, IDE will display the rate of progress; when done uploading appears, the uploading process succeeded.
Software Setting
Arduino IDE Installation
Windows will prompt that a new USB device, named DFU was found when connecting PS to the PC with USB. Then, windows will open the dialog box “found new hardware wizard”, check “no, not this time”, then click “next” to continue
Specify “usb32” in Atmel\AVR Jungo USB installation directory to install driver.
If everything goes well, windows will install the corresponding driver.
Now, you can find the corresponding Brainwave device in device manager of windows.
1. Click configuration > printer setting
2. Set the communication port (the COM port forBrainwave) and the Baud rate. Then click ok
3. Click “connect”> upload. Choose the GCODE file you want to print.
firmware
#define BAUDRATE 250000
#define MOTHERBOARD 82
This parameter is set for board type. 3D Printer has many types of main board, and the settings of IOs are different, therefore, the parameter has to correspond to the type of your board, or it can’t operate normally. The parameter of Brainwave should be 82(single- nozzle). For other board, you can refer to the annotation on the board.
#define EXTRUDE_MINTEMP 170
Extensible Applications
Exp:IIC、RS232、GPIO,JTAG
FAQS
2. How to solve it if the driver installation failed?
Click here to reinstall the driver(http://pjrc.com/teensy/serial_install.exe)
4.The step motor of X/Y/Z can’t run in the preset direction.
①the setting of code is not right or the motor id connected in the wrong direction.
②it is a matter of poor connection of the end stop.
③ the IC of drive motor is damaged.
