Sanguinololu
1.support multiple communication configurations :
3.Adapts Atmel's ATmega644P - ATmega1284 drop-in compatible. Currently, we use 1284P, the bootloader has been burned before shipping, and users can put it into use after burning the programming code.
size:100mm x 60mm
weight:73g
Software Resources
Pc software:
Sanguinololu drive: http://www.geeetech.com/wiki/index.php/Sanguinololu
Interface specifications
- 2 ADC interfaces for thermometry: one for extruder and another for hotbed.
- 3 PWM to control extruder, hotbed and fan.
- 3 end stops for x/y/z axis( mechanical, optical or hall sensor)
Jumper Instruction=
File Burning
Click the check“ File:Button 1.jpg” button to check if it is right and then click the “
” button to upload firmware, as shown below.
file
firmware download
