Raspberry Pi Camera Module
Revision as of 06:38, 6 August 2014 by Admin (talk | contribs)
This camera module is capable of 1080p video and still images, the size as around 25 x 20 x 9 (mm). It can be directly connected to your Raspberry Pi by CSI. The CSI is designed especially for the camera. The lens of the module is replaceable so that it is convenient to replace to make sure getting highest quality image for the user. The sensor has a native resolution of 5 megapixel and a fixed focus lens onboard. In terms of still images, the camera is capable of 2592 x 1944 pixels, and supports 1080p30, 720p60 and 640x480p60/90.
  • 5MP sensor,
  • Wider image, capable of 2592x1944 stills, 1080p30 video
  • 1080p video supported
  • CSI
  • Size: 25 x 20 x 9 mm
Connect the camera
The flex cable inserts into the connector situated between the Ethernet and HDMI ports, with the silver connectors facing the HDMI port. The flex cable connector should be opened by pulling the tabs on the top of the connector upwards then towards the Ethernet port. The flex cable should be inserted firmly into the connector, with care taken not to bend the flex at too acute an angle. The top part of the connector should then be pushed towards the HDMI connector and down, while the flex cable is held in place.
Documents
Information(OV5647) [1]
Datasheet(OV5647) Media:Ov5647full.pdf Quick Start Guide [2]
