MPR121 touch sensor module
Revision as of 03:07, 30 July 2014 by Admin (talk | contribs) (Created page with "==Introduction== File:Mpr121-1.jpg MPR121 touch sensor module is a kind of capacitive touch keyboard plate controlled by MPR121. It outputs the signal that the keys rec...")
