Metal J-head short-distance
This product adopts high-quality aluminum alloy heat radiator and brass nozzle, with stainless steel pipe as feeding pipe, which ensures good heat insulation effect and prevents blockage. Besides, its surface is covered with anodic oxide coating, which can resist oxidation corrosion and increase nozzle hardness, thus ensuring better heat insulation, stronger corrosion resistance as well as finer and more stable printing.
Feature
Configurable cooling fan, cooling effect.Assembled short-distance J-head with fan for bowden extruder
Product Introduction
| Molding form | FDM |
| Material | Metal |
| Movement speed | 50cc |
| Outline dimensions | 70*25*25mm L/H/W) |
| Weight | 68g |
Click here to buy Metal J-head short-distance
