PEEK J-head long-distance
Revision as of 12:38, 17 June 2014 by Admin (talk | contribs) (→Advantages)
Advantages
  • Internally, the filament path is identical to that of an already proven design.
  • The design is simple as the number of custom machined parts is kept to a minimum.
  • If necessary, the PTFE liner can be replaced by using an off-the-shelf piece of PTFE tubing.
  • The PTFE is not stressed nor used to provide support. This reduces a point of failure that is part of other designs.
  • A resistor is used as a heater. There is no need to wrap nichrome wire or to bake a heater core.
  • Heat transmission is improved as there is no thermal junction where a separate heater screws onto the nozzle.
Product Introduction
Printing resolution 0.1mm
Molding form FDM
Material Metal
Nozzle temperature 180℃-240℃
Outline dimensions 18*65*15mm L/H/W)
Weight 50g
Input voltage default to 12V
Thermisto 100K 1% high-precision NTC Thermistor
Cartridge heater 12V 30W
