Arduino Voice Recognition Module
Revision as of 06:37, 29 April 2014 by Admin (talk | contribs) (→Document)
Headline text
We've beening thinking about a module which helps to control other devices by voice and it will not cost too much. Finally we designed this module. Well, what can this module do? It can recognize as much as 15 voice instruction, which is suitable for most cases involving voice control.
Parameters
1、Voltage:4.5-5.5V
2、Current:<40mA
5、Size: 30mm x 47.5mm
Example
1. Recording
Please record the following voice instrctions in order :
1、WHITE
2、RED
3、GREEN
4、BLUE
5、OFF
2. Hardware connection
3. Code
delay(2000);
Serial.write(0xAA);
Serial.write(0x37);
delay(1000);
Serial.write(0xAA);
Serial.write(0x21);
while(Serial.available())
com = Serial.read();
switch(com)
case 0x11:
break;
case 0x12:
break;
case 0x13:
break;
case 0x14:
break;
case 0x15:
break;
Product list
1、Voice recognition Module x1
2、 USB-TTL module
3、Mic x1
4、4 pin cable x1
The Manual:File:Voice Recognize manual
