Update firmware
- Make sure that the Crazyflie is disconnected from the client and powered off
- Go to the menu Crazyflie→Bootloader
- Click “Initiate bootloader cold boot”
- Power on the Crazyflie within 5 seconds using the battery (not USB), the booloader should now connect
- Press “Browse” and select the binary you want to download (e.g. cflie.bin)
- Press “Program” and wait
- Press “Restart in firmware mode”
- To check the firmware version, under the View menu, open up Tabs→Console tab and look at the output when connecting to the Crazyflie.
