Quadcopter
Revision as of 01:55, 14 November 2013 by Admin (talk | contribs) (→Usage)
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter
  • A crazyradio
2.Assembly you can assemble it as follows '''Asssembly'''''Italic text''
3 Start to flying
  • Start up the application
  • Press Connect
Update firmware
The latest firmware for the Crazyflie Nano Quadcopter can be found here [4]
  • Make sure that the Crazyflie is disconnected from the client and powered off
  • Go to the menu Crazyflie→Bootloader
  • Click “Initiate bootloader cold boot”
  • Power on the Crazyflie within 5 seconds using the battery (not USB), the booloader should now connect
  • Press “Browse” and select the binary you want to download (e.g. cflie.bin)
  • Press “Program” and wait
  • Press “Restart in firmware mode”
  • To check the firmware version, under the View menu, open up Tabs→Console tab and look at the output when connecting to the Crazyflie.
