Reprap Ramps1.4 RRD Fan Extender
- max 20V
- 2 (PWM controllable) channels (D6/D11)
- max 0.5A per channel (enough for a really big fan)
- flexible output voltage (you can connect the RRD-FAN-EXTENDER to 12V,5V,... in order to support the output voltage you need)
- each channel has a fly back diode
- easy setup (plug and play)
- already supported by Marlin firmware (choose "#define MOTHERBOARD 34")
- easy to adapapt to other firmware (e.g. Sprinter: just change "#define FAN_PIN 6" in "pins.h")
Firmware:
Firmware:
Configuration:
as shown in the product description
TEST
Hardware required:
void setup() {
pinMode(11, OUTPUT); pinMode(6, OUTPUT);
void loop() {
digitalWrite(11, HIGH);
digitalWrite(6, LOW);
delay(5000);
digitalWrite(11, LOW);
digitalWrite(6, HIGH);
delay(5000);
2.Connecting follow this picture:
3. Power up ,two fans will take turns to rotate
