Printerboard
Revision as of 08:59, 30 April 2013 by Admin (talk | contribs) (→Features)
-- 128kb Flash
Thermistor Connectivity: 2
-- on-board USB connectivity
-- UART1 (RX and TX)
-- I2C (SDA and SCL)
-- SPI (MOSI, MISO, SCK)
-- PWM pin (1)
-- Analog I/O (6)
Benefits of this Design
Integrated micro-SD Card slot
Compatible Firmware
p=564].
Bootloaders
easily achieved.
Installing A Bootloader
fail.
each bootloader.
Loading Firmware (Windows)
 1. CDC BOOTLOADER (Arduino Bootloader)
  In Arduino 022, open firmware
  2.Choose [BootloaderCDC]Teensylu/Printrboard from the Arduino Tools-->Board menu, and select the COM port associated with your Printrboard's bootloader. See                        Lincomatic's How to Program an AT90USB1286/Teensylu/Printrboard with Arduino article[15] for help configuring Arduino.
  3.Click File --> Upload to Board.
  4.Arduino will compile and upload firmware. You should see an error a few seconds after the firmware compiles. This is because the AT90USB has successfully exited the bootloader.
  5. Press Reset. You may need to disconnect and reconnect the USB and power cables.
  HID BOOTLOADER
  2.Compile firmware within Arduino. You will need to copy and paste the compiled .HEX file into the HID application directory. The HEX file is saved in the temp folder,     C:\users\{currentuser}\appdata\temp\build1234567890\Firmware_Name_Here.cpp.hex
  4.  Disconnect and reconnect the USB and power cables.
 DFU BOOTLOADER
  1.Open Atmel's FLIP software.
  3.Compile firmware within Arduino. You will need to copy and paste the compiled .HEX file into the HID application directory. The HEX file is saved in the temp   folder, C:\users\{currentuser}\appdata\temp\build1234567890\Firmware_Name_Here.cpp.hex
  6.Click the Run button
Loading Fi==rmware (Linux)
DFU BOOTLOADER
6.press the reset button
11.lsusb should say 'VOTI'
Setup
Stepper Motors
A - Phase 1+
B - Phase 1-
C - Phase 2+
D - Phase 2-
Endstops
follows:
Switch NC
No connection
Switch COMMON
For optos:
Signal Output
+5V
GND
Heaters
Positive
Positive
Negative
Negative
Thermistors
Lower Power Fan
Board Power
USB
Schematic
Click here:
