Breakout Board for microSD Transflash
Revision as of 03:27, 25 February 2013 by Admin (talk | contribs)
  • SPI mode
  • Support voltage:3.0 to 3.6V
  • Up to 50 MB/sec data transfer rate
  • Sits directly on a Arduino
  • Also be used with other microcontrollers
Sometime you're not sure whether a card is working or not,you must test it.
Now,let's go.
// include the SD library:
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
  while (!Serial) {
pinMode(10, OUTPUT);     // change this to 53 on a mega
return;
 } else {
// print the type of card
switch(card.type()) {
   case SD_CARD_TYPE_SD1:
     Serial.println("SD1");
     break;
   case SD_CARD_TYPE_SD2:
     Serial.println("SD2");
     break;
   case SD_CARD_TYPE_SDHC:
     Serial.println("SDHC");
     break;
   default:
     Serial.println("Unknown");
if (!volume.init(card)) {
   return;
 uint32_t volumesize;
 Serial.println();
 volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
 volumesize *= volume.clusterCount();       // we'll have a lot of clusters
 volumesize *= 512;                            // SD card blocks are always 512 bytes
 Serial.println(volumesize);
 volumesize /= 1024;
 volumesize /= 1024;
 root.openRoot(volume);
void loop(void) {
Open Serial Monitor
OK,the card is working.
