MMA7361 Triple Axis Accelerometer Breakout
Revision as of 02:50, 29 August 2012 by Admin (talk | contribs) (→Example code)
This is a breakout for freescale mma7361l analog three axis accelerometer.The MMA7361L is a low power, low profile capacitive micromachined accelerometer featuring signal conditioning, a 1-pole low pass filter,temperature compensation, self test, 0g-Detect which detects linear freefall,and g-Select which allows for the selection between 2 sensitivities. Zero-g offset and sensitivity are factory set and require no external devices. The MMA7361L includes a Sleep Mode that makes it ideal for handheld battery powered electronics.
  • Low Voltage Operation: 2.2 V – 3.6 V
  • High Sensitivity (800 mV/g @ 1.5g)
  • Selectable Sensitivity (±1.5g, ±6g)
  • Fast Turn On Time (0.5 ms Enable Response Time)
  • Self Test for Freefall Detect Diagnosis
  • 0g-Detect for Freefall Protection
  • Signal Conditioning with Low Pass Filter
  • Robust Design, High Shocks Survivability
  • RoHS Compliant
  • Environmentally Preferred Product
  • Low Cost
Here is the guide illustrates how to connect an Arduino to the MMA7361 Triple Axis Accelerometer Breakout. The following is a table describing which pins on the Arduino should be connected to the pins on the accelerometer:
  1. include <AcceleroMMA7361.h>
AcceleroMMA7361 accelero; int x; int y; int z;
void setup() {
 accelero.begin(13, 12, 11, 10, A0, A1, A2);
 accelero.setARefVoltage(5); //sets the AREF voltage to 3.3V
 accelero.setSensitivity(LOW); //sets the sensitivity to +/-6G
 accelero.calibrate();
void loop() {
 x = accelero.getXAccel();
 y = accelero.getYAccel();
 z = accelero.getZAccel();
 Serial.print("\nx: ");
 Serial.print(x);
 Serial.print(" \ty: ");
 Serial.print(y);
 Serial.print(" \tz: ");
 Serial.print(z);
 Serial.print("\tG*10^-2");
 delay(500); //make it readable
Click here to buy MMA7361 Triple Axis Accelerometer Breakout
