Arduino IR Remote Control
The new ultra-thin 38K universal infrared remote control, NEC encoding format 1-21-key remote control, USB port stereo, car MP3, foot bath, lighting, digital photo frame, microcontroller development board, learning board, etc..
Feature
- Remote control distance: more than 8 meters
- Launch tube infrared wavelength: 940Nm
- Crystal: the oscillation frequency of 455 KHz
- IR carrier frequency: 38KHz
- Encoding: the encoding format of the NEC, upd6122 encoding scheme, the user code 00FF, key coding below picture
- Size: 86 * 40 * 6mm
- Frequency: 38K
- Power supply: CR2025/160mAH
- Button: free height is less than 3mm, the force 200-350g, the life of more than 200 000
- You need a IR receiving breakout to detect the IR signal and decodes it as HEX code, then dispaly it on the serial monitor.
S -> D11 VCC -> 5V GND -> GND
#include <IRremote.h>
IRrecv irrecv(RECV_PIN);
decode_results results;
void loop() {
Click here to buy [Arduino IR Remote Control]
