Geeetech M1S 3D printer
Printer Introduction
The GEEEETECH M1S is a mini high-speed 3D printer that supports WiFi connectivity and app control. It features a pressure leveling system, a close-range extruder, a heated bed, and an automatic nozzle wiper, with a maximum printing speed of 250mm/s. The app allows for printing status monitoring, parameter adjustment, model library preview, and remote control, combining high efficiency, intelligence, and convenience.
Appearance
Watch the M1S unboxing video and M1S quick guidel before assembling the printer.
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Printing materials: PLA, TPU, PETG, Silk PLA, Wood polymer
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to clean the hotend
If you need to clean the hotend, you can refer to this tutorial: Click here
How to Replace the hotend
If you need to replace the hotend, you can refer to this tutorial: Click here
How to replace the nozzle
If you need to replace the nozzle, you can refer to this tutorial: Click here
If you need to replace the control board, you can refer to this tutorial: Click here
How to Replace the Screen
If you need to replace the Screen, you can refer to this tutorial: Click here
How to Clean the Extruder
If you need to clean the extruder, you can refer to this tutorial: Click here
How to Replace the Extruder
If you need to replace the extruder, you can refer to this tutorial: Click here
How to Automatically Level
If you need to automatically level, you can refer to this tutorial: Click here
How to Manually Level
If you need to manually level, you can refer to this tutorial: Click here
