Geeetech M1S 3D printer
Printer Introduction
The GEEEETECH M1S is a mini high-speed 3D printer that supports WiFi connectivity and app control. It features a pressure leveling system, a close-range extruder, a heated bed, and an automatic nozzle wiper, with a maximum printing speed of 250mm/s. The app allows for printing status monitoring, parameter adjustment, model library preview, and remote control, combining high efficiency, intelligence, and convenience.
Appearance
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Printing materials: PLA, TPU, PETG, Silk PLA, Wood polymer
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to clean the hotend
If you need to clean the hotend, you can refer to this tutorial: Click here
How to Replace the hotend
If you need to replace the hotend, you can refer to this tutorial: Click here
How to replace the nozzle
If you need to replace the nozzle, you can refer to this tutorial: Click here
If you need to replace the control board, you can refer to this tutorial: Click here
How to Replace the Screen
If you need to replace the Screen, you can refer to this tutorial: Click here
