Geeetech M1 3D printer
Printer Introduction
Appearance
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to clean the hotend
How to Replace the hotend
How to replace the nozzle
How to Replace the Screen
How to Clean the Extruder
1. Turn the Z-axis bearing counterclockwise to move the extruder downward until the nozzle is about 3 cm away from the printing platform.
2. Use an M2 screwdriver to unscrew the two screws of the extruder cover and place the extruder cover on the x-axis bracket.
3. Use an M3 screwdriver to unscrew the two screws securing the extruder assembly to the heat sink and remove the extruder assembly. Remember to remove the Teflon tube in advance. (As shown in Figure 4, press down the black part with your index and middle fingers simultaneously, then pull out the Teflon tube with your other hand.)
4. Use an M3 screwdriver to unscrew the two screws that secure the motor and extruder.
5. Separate the motor and extruder and place the motor on the x-axis bracket.
6. First open the back cover of the extruder, then take out the optical shaft and unscrew the fixing screws, and finally take out the pressing wheel and the pressure rod.
7. Clean the remaining impurities inside the extruder, especially all holes must be inspected.
8. First install the optical axis and the pressure rod, then install the pressure wheel, and then tighten the screws (lock the hand screws and lock them in place, do not tighten them too much), and finally cover the back cover of the extruder.
9. After aligning the pressure wheel and the motor with the empty space and inserting them, use an M3 screwdriver to lock the motor and extruder.
10. Align the extruder with the Teflon tube on the radiator and insert it. Use an M3 screwdriver to lock the extruder on the radiator.
11.Use an M2 screwdriver to fix the extruder cover.
How to Replace the Extruder
How to Automatically Level
How to Manually Level
How to adjust the X-axis belt
How to install a detached print head
How to remove the upper frame
How to remove the middle frame
How to Replace a Heated Bed Kit
Mainboard wiring diagram
M1 1KG consumables installation video
Download link of M1 1KG model file
Black Screen
Minimum Temperature Error
Filament cannot be extruded
3、 The printer is blocked
Solution:
Print file is not displayed
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-240℃
Fan Cooling: 100%
