Filament
Revision as of 06:59, 30 October 2025 by Admin (talk | contribs)
PLA
Bed temperature: 60-70 °C
Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups
Retraction speed: 45 mm/s
Cooling fan speed:100%
(1) Level the hotbed
(2) Change the Z-offset
(3) Clean the hotbed
Silk PLA keeps clogging
Wood PLA keeps clogging
Carbon Fiber PLA
Clean the nozzle: Clean the nozzle and extruder regularly to prevent carbon fiber particles from accumulating.
Marble PLA
Marble PLA is a special type of PLA (polylactic acid) material that is mixed with stone powder or other additives to simulate the look and texture of marble.
(1) Marble PLA has the following characteristics:
Appearance: Unique marble texture and feel
Easy to print: Good fluidity and low warpage
Environmental protection: Biodegradable and environmentally friendly
(2) When using marble PLA, please note the following:
Nozzle selection: Because it contains marble particles, long-term use may cause nozzle wear. It is recommended to use a wear-resistant nozzle
Humidity control: It should be stored in a dry environment, using sealed bags and desiccant to prevent moisture absorption
Printing speed: It is recommended to use a medium speed of 30 to 60 mm/s to ensure printing quality and texture effect
High Speed PLA
PETG
Bed temperature: 70-80 °C
Retraction speed: 25 mm/s
Cooling fan speed: 30-40%
Build plate adhesion: Brim
ABS
Bed temperature: 80-100 °C
Cooling fan speed: 0%
TPU
Nozzle temperature: 200-230℃
Bed temperature: 60℃
Retraction distance: 2.5 mm
Retraction speed: 80 mm/s
Cooling fan speed: 100%
Build plate adhesion: Edge
ASA
Acrylonitrile Styrene Acrylate (ASA) has mechanical properties similar to ABS—strong, tough, and impact-resistant—with better weather resistance (UV, moisture, extreme temperatures), ideal for outdoor use. Less prone to warping than ABS, it benefits from a heated bed and enclosure. Fewer toxic fumes than ABS, but ventilation is still needed.
As for Geeetech ASA, the perfect settings is shown as below:
Nozzle temperature: 240-270℃
Bed temperature: 80-110℃
Cooling fan speed: 40-50%
Build plate adhesion: Brim & Skirt
Applicable to Bambu Lab AMS LITE
001 002 003
004 005
Solution for consumables entangled with each other
