Geeetech M1 3D printer
Printer Introduction
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
Print file is not displayed
First of all, it is stated that the slice file must be in .gcode format. The printer cannot recognize other formats
Please format the TF card first and download the test file from the official website.official website official website.
Save the downloaded .gcode file to the TF card, then insert the TF card into the printer to see if the slice file can be displayed normally
1. If the slice file cannot be displayed, please replace the new TF card and try again. If the new TF card can be displayed normally, it is the fault of the old TF
2. If the slice file still does not display after trying multiple TF cards, it is the TF card driver on the motherboard. You need to replace it with a new one
(2) Click Import
(3) Click Import Configs...
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 30%
