Geeetech M1 3D printer
Printer Introduction
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Printer Size: 279*200*298 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
3.The extruder is not working
Rough edges and corners
The side edges are uneven
Nozzle temperature: 220-230℃ Bed temperature: 30-60℃
How to print ABS
Nozzle temperature: 230-250℃ Bed temperature: 90-110℃
Fan speed: 0%
How to print PETG
Nozzle temperature: 220-250℃ Bed temperature: 70-80℃
