Geeetech M1 3D printer
Printer Introduction
Geeetech Mozi is a very good 3D printer on the market.
1 Printer Introduction
2 Printer Maintenance
2.1 How to Clean the Nozzle
2.2 How to Replace the Hot End
2.3 How to Replace the Screen
2.4 How to Replace the Control Board
2.5 How to Automatically Level
2.8 How to Manually Level
3 Troubleshooting
3.1 Black Screen
3.2 Update Firmware
3.3 Minimum Temperature Error
3.4 Automatic Leveling Failed
3.5 How to Import Profiles into Cura
3.The extruder is not working
The thickness of the first layer printed is uneven
Rough edges and corners
The side edges are uneven
Nozzle temperature: 220-230℃ Bed temperature: 30-60℃ Print speed: 30-40mm/s Initial print speed: 20mm/s Retraction: Disabled
How to print ABS
Nozzle temperature: 230-250℃ Bed temperature: 90-110℃ Print speed: 50-60mm/s Initial print speed: 20mm/s Number of slower layers: 5-10 (The first few layers are printed slower that the rest of the model, to get better adhesion to the build plate.)
Fan speed: 0%
Build plate adhesion: Brim Raft shield: Enable
How to print PETG
Nozzle temperature: 220-250℃ Bed temperature: 70-80℃
