Filament
PLA
Bed temperature: 60-70 °C
Print speed: 60-100 mm/s
Initial layer height: 0.3 mm
Initial layer print speed: 20 mm/s
Travel Speed: At least 120 mm/s
Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups
Retraction speed: 45 mm/s
Cooling fan speed:100%
(1) Level the hotbed
(2) Change the Z-offset
(3) Clean the hotbed
Silk PLA keeps clogging
Wood PLA keeps clogging
High Speed PLA
PETG
Bed temperature: 70-80 °C
Print speed: 40-50 mm/s
Retraction speed: 25 mm/s
Cooling fan speed: 30-40%
Build plate adhesion: Brim
ABS
Bed temperature: 80-100 °C
Cooling fan speed: 0%
TPU
Nozzle temperature: 200-210°C
Bed temperature: 60 °C
Print speed: 30-40 mm/s
Applicable to Bambu Lab AMS LITE
001 002 003
004 005
Solution for consumables entangled with each other
For the problem of consumables being intertwined, here are some solutions: 1. Separate the entangled parts: Separate the entangled parts of the filament one by one, and operate carefully to ensure that the filament will not be further entangled or damaged.
2. Rewind the filament: Rewind the separated filament, ensuring that it is wound in the clockwise direction of the outer ring of the filament. Avoid random or reverse winding to avoid causing the filament to stagger or become entangled again.
3. Use appropriate tools: You can use appropriate auxiliary tools to help rewind the filament to ensure more precise and stable operation.
4. Adjust the position of the filament: Make sure that the filament reel on the printer is in the correct position and will not interfere with the normal supply and winding of the filament.
5. Regular maintenance and cleaning: Regularly clean the printer’s filament path and surrounding area to ensure that no accumulated dust or debris affects the normal operation of the filament.
Youtube video link address: https://youtube.com/shorts/6L3DUEzIdVY?feature=share
