GLA10
Tips
1. Please read this manual carefully for using GLA10 correctly.
2. Please scan the QR code or log in to our website to get the G-code file that GLA10 needs.
3. Please pay attention to safety when leveling the GLA10 hot bed, so as not to hurt your fingers by the moving hot end.
Leveling Preparation
2. Please enter the URL https://www.geeetech.com/wiki/index.php/GLA10 in the browser, or scan the QR code below to visit our website. Then download the GLA10 related G- code file. We provide the corresponding G-codes for different hotbed sizes. The files with the "Level" mark are the leveling auxiliary files, and the G-code files with the "Test" mark are the test files after the adjustment is completed.
3. Please select the correct G-code file according to the size of your 3D printer heat bed, copy the G-code to the Micro SD card and insert it into the printer.
GCode generator for GLA10
Please click the following link to enter the leveling Gcode generator. Edit the heating bed size, layer height, LED trigger height, and leveling time of each point to generate the Gcode code, and then copy or export the Leveling Gcode to the TF card.
[[1]]
Start Leveling
Product Parameters
Battery parameter:CR2032,3V
Product weight:14.5g
Packing weight:52g
