Geeetech Mizar M 3D printer
Printer Introduction
Unique Separated Color Module
Main specification
Technology: FDM
Printing Thickness: 0.1-0.2mm
Nozzle Diameter: 0.4mm
Printing Accuracy: ±0.1mm
Printing Speed: 20~150mm/S
Hotbed Max Temperature: 110℃
Nozzle Max Temperature: 250℃
Working temperature: 10-40℃
Electric Parameter
Hotbed Size: 260*260mm
Net Weight: 10.2kg
Gross Weight: 13kg
How to replace the Separate Color Module
If you need to replace the color separation module, please click on the video link below to replace it according to the tutorial. replace the Separate Color Module
How to clean up the Gradient Color Module
If you need to clean up the Gradient Color Module, please click on the video link below to replace it according to the tutorial. Clean up the Gradient Color Module
How to replace the print head
If you need to replace the print head, please click on the video link below to replace it according to the tutorial. Replace the print head
How to manual leveling of Geeetech Mizar M
If you need to manual leveling, please click on the video link below to replace it according to the tutorial. Manual leveling of Geeetech Mizar M'
How to auto leveling of Geeetech Mizar M
If you need to manual leveling, please click on the video link below to replace it according to the tutorial. Auto leveling of Geeetech Mizar M'
Hotend clogging
Mintemp error
Filament sensor
How to update:
4.Update is complete.
Notice:
Nothing is printing
Automatic leveling failed
(a)3D Touch is abnormal
(b)Homing failed
(c)The first layer is messy
How to slice with Cura
Mizar M Cura Configuration
File Path
Cura 5.X
Cura 4.X
Cura Profile
Separate Color Printing
Gradient Color printing
- G-code Instructions
M163 Set a mix factor
M164 Save mix factor
M166 Gradient for Marlin 2.0
A= Start z height
Z= End z height
I= Start Virtual Tool
J= End Virtual Tool
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P1; 100% Red
M163 S1 P0; 0% Green
M163 S0 P0; 0% Red
M163 S1 P1; 100% Green
M166 A0 Z250 I0 J1 S1
mix.
M166 A0 Z250 I0 J1 T3
T3
M166 T
T0
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1 ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2 ;T2=50/50
M163 S0 P1
M163 S1 P0
M164 S0 ;T0=100/0
M163 S0 P0
M163 S1 P1
M164 S1 ;T1=0/100
M163 S0 P0.5
M163 S1 P0.5
M164 S2 ;T2=50/50
How to slice with Easy Print
Gradient Color Printing
How to slice with Prusa Slicer
Mizar M Prusa Configuration
How to slice with Simplify 3D
Spring steel sheet problem
