Geeetech Alkaid 3D Printer
Printer Introduction
Alkaid is made in black and white with 6.08 "2K resolution, enabling X/Y accuracy up to 0.05mm. Alkaid's z axis uses a high-cost linear guide rail, which has the characteristics of high rigidity, high load, automatic self-aligning, absorbing assembly errors, etc., which can effectively improve the overall printing quality of 3D printers. A new generation of matrix light source, using 15 pieces of high-light power quartz lamp beads, with professional optical materials made of matrix lenses, so that ultraviolet irradiation on the LCD screen more uniform, higher intensity, effectively improve the printing speed and accuracy.
The rugged Alkaid innovates by integrating UV lamp beads on the aluminum substrate at the bottom of the machine, allowing for greater heat dissipation area. With the cooling fan, it can effectively reduce the temperature of the lamp board and extend the service life of the UV lamp beads. Alkaid is easy to operate and affordable, making it ideal for beginners and amateurs. In addition, geeetech is able to provide ODM and OEM custom design and manufacturing.
Main Specification
Printing Technology LCD Light Curing Surface Forming Technology
Printing Size 82X130X190 mm
XY Resolution 0.051 mm
LCD Size 6.08 inch
LCD Resolution 2560X1620 Pixels
Z-axis Precision 0.001 mm
Layer Thickness 0.01~0.2 mm
Printing Speed 30 mm/h
UV Lamp Rated Power 45 W
Resin 405 nm Wavelength Ultraviolet Resin
Slicer Software CHITUBOX
File Type .CTB
Working Environment Temperature 10 ℃~35 ℃
Working Environment Humidity 30%~70%
Power Adapter Input: 100V~240V, 50/60Hz, Output: 12V/5A
Connectivity USB
Touch Screen 3.5 -Inch Full-color Touch Screen
LCD Screen Resolution 2K Forming Screen
Printer Size 286(L)*226(W)*372(H) mm
Package Size 353(L)*293(W)*464(H) mm
Net Weight 4.2 kg
Gross Weight 5.8 kg
Watch the user manual and unboxing video before assembling the printer.
How to replace UV light
How to replace motherboard
