Geeetech Alkaid 3D Printer
Printer Introduction
Alkaid is made in black and white with 6.08 "2K resolution, enabling X/Y accuracy up to 0.05mm. Alkaid's z axis uses a high-cost linear guide rail, which has the characteristics of high rigidity, high load, automatic self-aligning, absorbing assembly errors, etc., which can effectively improve the overall printing quality of 3D printers. A new generation of matrix light source, using 15 pieces of high-light power quartz lamp beads, with professional optical materials made of matrix lenses, so that ultraviolet irradiation on the LCD screen more uniform, higher intensity, effectively improve the printing speed and accuracy. The rugged Alkaid innovates by integrating UV lamp beads on the aluminum substrate at the bottom of the machine, allowing for greater heat dissipation area. With the cooling fan, it can effectively reduce the temperature of the lamp board and extend the service life of the UV lamp beads. Alkaid is easy to operate and affordable, making it ideal for beginners and amateurs. In addition, geeetech is able to provide ODM and OEM custom design and manufacturing.
Printing Parameter
Printing Technology
LCD Light Curing Surface Forming Technology
Printing Size
82X130X190 mm
XY Resolution
0.051 mm
LCD Size
6.08 inch
LCD Resolution
2560X1620 Pixels
Z-axis Precision
0.001 mm
Layer Thickness
0.01~0.2 mm
Printing Speed
30 mm/h
UV Lamp Rated Power
45 W
Resin
405 nm Wavelength Ultraviolet Resin
Slicer Software
CHITUBOX
File Type
.CTB
Working Environment Temperature
10 ℃~35 ℃
Working Environment Humidity
30%~70%
Power Adapter
Input: 100V~240V, 50/60Hz, Output: 12V/5A
Connectivity
USB
Touch Screen
3.5 -Inch Full-color Touch Screen
LCD Screen Resolution
2K Forming Screen
Printer Size
286(L)*226(W)*372(H) mm
Package Size
353(L)*293(W)*464(H) mm
Net Weight
4.2 kg
Gross Weight
5.8 kg
