Filament
Revision as of 06:11, 6 May 2023 by Admin (talk | contribs) (TPU)
PLA
As for Geeetech PLA, the perfect settings in Cura slicer is shown as below: Nozzle temperature: 180-220 °C Bed temperature: 60-70 °C Print speed: 60-100 mm/s Initial layer height: 0.3 mm Initial layer print speed: 20 mm/s Travel Speed: At least 120 mm/s Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups Retraction speed: 45 mm/s Cooling fan speed:100% Initial layer cooling speed: 0% Build plate adhesion: Skirt or Brim
PETG
As for Geeetech PETG, the perfect settings in Cura slicer is shown as below: Nozzle temperature: 220-230 °C Bed temperature: 70-80 °C Print speed: 40-50 mm/s Initial layer height: 0.3 mm Initial layer print speed: 20 mm/s Travel Speed: At least 120 mm/s Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups Retraction speed: 25 mm/s Cooling fan speed:30-40% Initial layer cooling speed: 0% Build plate adhesion: Brim
ABS
As for Geeetech ABS, the perfect settings in Cura slicer is shown as below: Nozzle temperature: 230-250 °C Bed temperature: 80-100 °C Print speed: 40-50 mm/s Initial layer height: 0.3 mm Initial layer print speed: 20 mm/s Travel Speed: At least 120 mm/s Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups Retraction speed: 25 mm/s Cooling fan speed:0% Initial layer cooling speed: 0% Build plate adhesion: Brim
TPU
TPU stands for “thermoplastic polyurethane”. TPU is a specific type of TPE and is on the more rigid than other flexible filaments, making it easier to print with. The Shore hardness value of Geeetech PLA is 95A. You will need TPU if your print bends, stretches or compresses.
As for Geeetech TPU, the perfect settings in Cura slicer is shown as below: Nozzle temperature: 200-210°C Bed temperature: 60 °C Print speed: 30-40 mm/s Initial layer height: 0.3 mm Initial layer print speed: 20 mm/s Travel Speed: At least 120 mm/s Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups Retraction speed: 25 mm/s Cooling fan speed:100% Initial layer cooling speed: 0% Build plate adhesion: Brim
