Geeetech Thunder 3D printer
Revision as of 10:19, 15 September 2022 by Admin (talk | contribs) (→FAQ)
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
Cura Configuration File
User Mode Introduction
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
G-code for main fan and auxiliary fan
Main Fan:
M106 P0 S128 ; ON MainFan 50%
Auxiliary Fan:
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
How to Acquire Support
Steps:
How to Buy
Click to Purchase
