Geeetech A20M 3D printer
Revision as of 10:26, 15 November 2018 by Admin (talk | contribs) (Document)
Geeetech A20M 3D printer, adopting open source GT2560 control board, delivers mix-color objects and greatly enriches your 3D printing life. Keeping the good performance of Geeetech’s portfolio of 3D printers, it aims to provide users with quality printout and satisfactory printing experience.
The modularized design makes it easy to build the printer in 3 steps. Its classic blue and black color combo imparts a touch of simplicity and excellence, embodying Geeetech’s commitment to quality products.
With its build volume as 255*255*255mm³and the classic Prusa I3 3D printers’ gantry structure, A20M makes the best of the building platform and enables you to view the printing details in 360°. Printing at the accuracy of 0.1mm, it delivers objects with smooth surface finish, clear angles and strong structure. Besides, A20M comes with filament detector and break-resuming capability, greatly enhancing your 3D printing experience. Its well-designed extruder greatly reduces the risk of clogging or leaking. A20M extruder cover features 360°ventilation design, greatly enhancing the dissipation of heat and guaranteeing excellent printing quality.
A20M extruder motor uses a gear train of 3:1 speed ratio, amplifying input torque and improving your printing experience. Adopting the modularized design for extruder wiring, A20M makes it easy to exchange the wire.
The V-shaped wheels and rails on each axis, made from wear-resistant aluminum profile, could, in a large measure, reduce the printing noise and offer you a quiet 3D printing environment.
A20M uses silicon carbide glass as its printing platform, greatly enhancing the adhesion of first layer and making it so easy to take down the print. In addition, A20M control board supports auto-leveling, an optional add-on. Just connect the auto-leveling sensor and adjust the related parameters. Saving the efforts of manual leveling.
1. Modularized Design for Easy Assembly
The modularized design makes it easy to build A20M in 3 steps.
2. Simple & Extraordinary
3. Color-Mixer Software
4. Mix-Color Printing Capability
5. 360° Ventilation Design
6. High-Performance Gear Train
7. Convenient Reset Button
8. Break-Resuming Capability
9. Modularized Extruder Wiring
10. Filament Detector
11. 3D Touch
12. Good-Adhesion and Uniform Heating
13. V-Shaped Rails & Wheels
14. Standard Volume Printing & 360° View
15. High Printing Accuracy
16. Open Source Control Board
17. App Smart Could 3D Printing
18. Parameters
Gallery
Videos
A20M Video View
Color-Mixer
A20M Quick Start
EasyPrint 3D for PC
Repetier-Host
Where to buy
Geeetech A20M 3D Printer
