Geeetech A30 3D Printer
Revision as of 06:46, 13 July 2018 by Admin (talk | contribs) (→FAQ)
1. The biggest printer ever
2. 3.2″ full-color touch screen Intuitive & Easy-to-use
3. Better adhesion
We choose silicon carbide glass with microporous coating as A30 building platform, without the need of attaching the masking tape. The silicon carbide glass is of chemical stability, high heat conductivity coefficient, good wear-resistance and can withstand extreme temperature. The special coating is inorganic and has a hardness of 8 Mohs, hence of high durability. Compared with common building platform, this kind of tempered glass is of better adhesion and flatness and easy to take prints off. Besides, it is easy to clean with water or alcohol.
4. 3D touch auto-leveling (Optional add-on)
5. Break-resuming capability
6. Filament detector
7.Wi-Fi enabled EasyPrint 3D App Convenient & Multifunctional
Remote control
8. Download EasyPrint 3D App
11. Upgrade firmware on-line
12. Good craftmanship
13. Bowden Extruder Remote design & Stable performance
15. Easy to assemble
16. Stable structure
17. Product display
Gallery
Videos
watch videos about Geeetech A30 3D Printer on Youtube
Geeetech A30 3D Printer User Manual
Geeetech A30 3D Printer Assembly Manual
Geeetech A30 3D Printer Brochure
Geeetech A30 printer
1. Q: What should I do when I got the machine?
A: You need to check the PSU work mode at first(220V/110V)
  Then check the package list.
  If something missing, you need to contact the sales at first.
  Then sales need to check your order number and resend you the parts.
2. Q: How to use the toolkit update the firmware for A30(I can't update the firmware via Easy print)?
A: You can refer to this post [1]
3. Q: Which silcing software should I select?
A: You can use the Easyprint3D/Repetier-host/Cura for slicing.
4. Q: I find my printer X/Y/Z axis motor or extruder motor direction is opposite and how to solve it?
A: You can refer to this post [2].It shows you how to change it.
5. Q: When the printer finished update firmware and the screen seems dead(Black/Blank screen)
A: You can try to restart the printer.If it still doesn't work.Refer to this post [3]
6. Q: I find my printer X/Y/Z axis motor can only run at the one side or "auto home" doesn't work.
A: You can refer to this post [4] and check the wires of endstop mount correctly or not
7. Q: I find my printer extruder doesn't work and how to solve it? A:You need to heat the nozzle up to 200℃ then try it again.
If it still doesn't work.You can swap the A4988 of the extruder and X-axis for a test.
Or you can refer to this post [5]
Where to buy
