Geeetech GTM32 Board
Revision as of 09:31, 23 May 2018 by Admin (talk | contribs) (→Features)
GTM32 is a fully self-developed control board by Geeetech for high-performance 3D printers. It keeps Geeetech’s uniformly optimized interface specifications, easy to assemble and with compact layout, high integration and high performance.
GTM32 control board (hereinafter referred to as the control board) adopts the current mainstream high-performance Cortex M3 core chip STM32F103, with its running frequency of up to 72MHz.The control board supports up to 4 stepper motors, namely, XYZ axial motor and an extruder. Users can replace the driving modules, such as A4988 and TMC2100 modules, according to their own needs. Besides, it employs the high performance USB serial chip FT232RL, which enables users to manipulate the control board via USB cable. Its output voltage is 12V.
i. With a buzzer on board.
Hardware Resources
5. 6 endstop interfaces
7. 3 interfaces for PWM fan
8. 3D Touch interface
Weight: 79.00 g
Interface specifications:
USB interface: USB B type
Software resources
Firmware:
Host software:
Printing and control software:
http://www.geeetech.com/wiki/images/3/36/SetupRepetierHost_1_00.zip
1. PSU: output voltage 12V
2. Hotbed interface:
3. Extruder interface:
Subdivision of Stepper Motor
Turn ON/OFF Subdivision
MS1 MS2 MS3
OFF OFF OFF full step
ON OFF OFF 1/2 step
OFF ON OFF 1/4 step
ON ON OFF 1/ 8 step
ON ON ON 1/16 step
How to Install firmware
A: One extruder at best.
A: 12V.
