GT2560A/GT2560A+
GT2560/GT2560A+ is a compact board that is integrated with the mighty function of the Arduino Mega2560+Ultimaker and Arduino Mega2560+ramps 1.4 on respect of both software and hardware and has more premium features: the streamlined interfaces effectively avoid the unnecessary troubles, well-regulated compaction of components highly integrated saves more space and easier to be mounted on most applications.
5 stepper motors, swappable driving modules, mighty ATmega2560 processor with 256k memory, 16MHz operating frequency, high-performance USB serial converter FT232RQ/CH340, all these make the GT2560 an ideal option for a 3D printer control board. What’s more, GT2560 can run over 12V to 24V which gives higher torque and higher rotation rate.
2. Adopt ATmega2560 as the main control chip, coupled with the high-performance USB serial converter FT232RQ/CH340.
Hardware resources:
12V/24V 15A and 12V/24V 10A power supply
3 input for12V cooling fan
1 PWM output
Dimension: 109mm*78mm*22mm
weight: 87 g
Source
GT2560A
GT2560A+
Interface specifications
2.HOT_BED: heat bed
5.LCD ENCODER: LCD panel
6.SD Card
2-2
Software setting
File Burning
firmware, as shown below.
Get Started
#define BAUDRATE 250000
#define MOTHERBOARD 7
#define EXTRUDE_MINTEMP 170
I3 PRO B [1]
I3 PRO W [2]
I3 PRO C [3]
I3 PRO X [4]
I3 A PRO [5]
Refer to this website Geeetech official forum
1.How many extruders can GT2560 support?
2.What is the power required?
4.Does it support auto leveling sensor?
- Yes.You can add 3dtouch/bltouch or others auto level sensor
How to get
Visit here now!
