Geeetech A30 3D Printer
Revision as of 06:21, 24 November 2017 by Admin (talk | contribs) (Features)
1. The biggest printer ever
2. 3.2″ full-color touch screen Intuitive & Easy-to-use
3. Better adhesion
We choose silicon carbide glass with microporous coating as A30 building platform, without the need of attaching the masking tape. The silicon carbide glass is of chemical stability, high heat conductivity coefficient, good wear-resistance and can withstand extreme temperature. The special coating is inorganic and has a hardness of 8 Mohs, hence of high durability. Compared with common building platform, this kind of tempered glass is of better adhesion and flatness and easy to take prints off. Besides, it is easy to clean with water or alcohol.
4. 3D touch auto-leveling (Optional add-on)
5. Break-resuming capability
6. Filament detector
7.Wi-Fi enabled EasyPrint 3D App Convenient & Multifunctional
Remote control
8. Download EasyPrint 3D App
11. Upgrade firmware on-line
12. Good craftmanship
13. Bowden Extruder Remote design & Stable performance
15. Easy to assemble
16. Product display
Gallery
Videos
watch videos about Geeetech A30 3D Printer on Youtube
Geeetech A30 3D Printer User Manual
Geeetech A30 3D Printer Assembly Manual
Geeetech A30 3D Printer Brochure
Where to buy
