Prusa I3 X
Geeetech Prusa I3 X is a new member of the prestigious Prusa I3 family, it was engineered to provide redefined usability, quality, performance and most important, best affordability in desktop 3D printer market. The Geeetech Prusa I3 X is made from piano-black laser-cut acrylic frame. To maintain the garage-built feel and the handmade charm, Geeetech Prusa I3 X is also a DIY kit, which provide you an unforgettable step-by-step learning experience of 3D printer from scratch. Geeetech Prusa I3 X has a wide range of customers , young or old, professional or amateur, as long as you have a passion for creativity, you can not afford to miss our Prusa I3 X.
  • Multiple 3D printing filament supportable: PLA,ABS, Wood-Polymer, Nylon, flexible PLA and PVA.
  • 200x200x170mm printing volume, just right for you.
  • 0.05mm printing precision.
  • 8-mm-thick laser cut acrylic frame for rigidity and long life.
  • Stainless steel rail rods, gears, bearings and connectors for smoother movement.
  • All metal pulleys for improved functionality and performance.
  • Super-flat aluminum alloy print surface for better adherence.
  • Quick-release feed gears for faster and fluent filament feeding.
  • filament size: 1.75mm.
  • nozzles size: 0.30mm, 0.35mm.
Printing specifications:
Build volume: 200 x200x140mm
Printing Precision: 0.1-0.3mm
Filament diameter: 1.75mm
Software:
File format: .STL, G-code
Temperature:
Electrical:
Power supply:
Input: 115V or 230V
Output:DC12V/0-15A
Mechanical:
Physical Dimensions & Weight:
Net weight: 8.7kg
Shipping weight: 10kg
Assembly
For detailed assembly instruction, please refer to here, or you can subscribe our Youtube for detailed videos.
Install the drivers
Windows 8
Windows Manual Install
Macbook (OS X) Manual Install
Click "Continue" in Read me.
Click "Continue" in License.
How To set up
1. Plug the USB into your Prusa I3 and the other end into your computer.
3. Open Repetier Host and ensure that you have a valid port selected for communications. To do this simply, click “Printer Settings” in the upper right-hand corner to bring up the printer settings menu.
4. Select the corresponding COM port, click OK to continue.
In Mac, you should finish step 5 in "Printer>Printer settings", step 4 is unnecessary
5. Hit "connect" in the upper left-hand corner, select GEEEtech PI3A. You should see the details of the connection in the console window in the bottom section of the screen. if your pronter is other models, you can select it, if you are not sure, you can skip it and connect directly.
6. On the right panel, click the "Manual Control" tab. Scroll down and click both heat extruder and heat print bed buttons to activate your heaters. You will know they are on if they turn a bright blue.
7. At the same time, you can click the arrows on the above panel to move the motors to check if they work well.
8. Click “load” to load the STL. File you need to print.
9. After loading, choose “slicer” > “configure” to set the printing configurations. You may need to wait for a minute.
10x. First, you need to set the layers and perimeters. As you can see in the following picture, all you need to set is the layer height and the first layer height. Leave the rest as default. (For each setting, you can get a prompt to refer)
11. Set the printing infill density and pattern. Refer to the prompt.
12. Set the printing speed. Again, refer to the prompt.
13. Filament setting. You just need to fill in the correct filament diameter.
14. After setting, do not forget to save the settings and name each setting.
15. Select the settings you save on the right panel. Then click the “Slice with slice3r”to generate G- code. You may have to wait for a while.
16. click slicer button and slice with Slic3r.
  • Here is a temp reference.
 Filament Type	Bed temp	Extruder temp
 PLA	        50-100	        190-210
 ABS	        70-110	         220-240
Leveling The Print Bed
Getting the bed level in relation to the X and Y axis is very important for getting prints to stick well and is one of the first steps you should do when receiving your printer . The first layer might have the right amount of squish in one area, but if another part of the bed is too low, that part of the print is more likely to come unstuck and begin to warp. The level is adjusted with the spring loaded screws, two at the front and one at the back. If you are using the standard kapton tape on the build platform and not a sheet of glass, you will need to poke holes in the tape in order to turn the leveling screws or print some thumbscrews and use a little super glue to screw them onto the bottom of the leveling screws. We suggest using the thumbscrew route so that you do not have to damage your kapton tape.
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
How to control on LCD
1.How to print from LCD
1)If you do not set the temperature of extruder and hot bed in g-code, you should manually heat up extruder and hotbed to proper temperature before printing.
2)If you do not set letting all the axes auto home in g-code, you should manually let all the axes auto home first.
Press the button>"Print from SD">Choose the file you want to print and press button.
Press button on LCD> “Prepare”>“Auto home”
Press the button>”Prepare”>”Move axis”>”Move 10mm/1mm/0.1mm”>”Move X/Y/Z/extruder”>Rotate the button> Press button
Slic3r Manual
FAQs & SOLUTIONs
2.How to unblock a nozzle
3.FAQs OF 3D printing
where to get
geeetech official oline store
