Building Instructions of Geeetech Prusa I3 X
Revision as of 06:21, 22 July 2015 by Admin (talk | contribs) (→26.Wiring)
Preparation
  • All the acrylic plates have been etched with part ID and the plate is covered with a sheet of kraft paper, you need to tear them off.
1. Assemble the threaded rods of Y axis
450mm threaded rod
53
2
M10 washer
33
8
M10 hex nut
A3
8
M10 spring washer
A4
6
Connecting fender
14
2
M10 nut <M10 nut < M8 spring washer<M10 washer in turn on the left
3) Thread theM10 washer < M8 spring washer < M10 nut < M10 nut< M8 spring washer < M10 washer in turn on the right
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
3.Mount the Y motor
stepper motor
No.63
1
Y motor holder
No.A13
1
M3 x12mm screw
No.22
3
M3 x 16mm screw
No.23
2
M3 square nut
No.16
2
Pulley
No.42
1
Fix the holder plate with 2 M3 x 16 screws and M3 square nut.
4.Y belt driving wheel
Driven wheel holder
No.40
1
624zz Ball Bearing
No.35
2
M3 x20mm screw
No.24
3
M4 x 25mm screw
No.31
2
M4 locking nut
No.16
2
wing nut
No.42
1
Step1. Thread the M3 x 20 screw through the bearing holder.
Step2. Put the M4 x25 screw through the holes with the two 624ZZ bearings in between. Lock the other end with a M4 lock nut. You may need a spanner to tighten locking nut.
5. Build the print platform
Building platform support
No.A15
1
Belt mount
No.41
1
M4 x 16mm screw
No.30
16
M4 washer
No.8
16
SCS8UU linear bearing
No.36
4
M3 x12mm screw
No.22
2
M3 washer
No.7
2
6. Mount the Y belt
Timing belt
No.39
1
M3 x8mm screw
No.21
2
M3 washer
No.7
2
  • Tips:
2. Loosen the Y idler wing nut when tightening belt onto the Y belt mount [No. 67] in order to make securing the belt to the block easier. Be sure to tighten wing nut fully  once done.
Watch the video here.
7.Left Z motor mount
M2.5 hex nut
No.11
2
M2.5x16mm screw
No.20
2
M3 x 16mm screw
No.23
3
M3 Square nut
No.16
3
end stop
No.52
1
Motor holder (left)
No.A4
1
Motor Holder support
No.A6
1
No.A7
1
Z endstop mount
No.A28
1
Step 1. Mount the endstop on the endstop mount with two M2.5 x 16screws and nut.
8.Right Z motor mount
M3 x 16mm screw
No.23
2
M3 Square nut
No.16
2
Motor holder (right)
No.A5
1
No.A6
1
No.A7
1
Assemble the motor holder ((right) and the motor holder support together, screw it up with 3 M3 x 16mm screw and M3 Square nut.
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
Main frame
No.A1
1
10.Side panel assembly
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
11.Main frame assembly
M3 x 16mm screw
No.23
2
M3 x 20mm screw
No. 24
4
M3 hex nut
No. 2
4
M3 square nut
No.16
6
M3 washer
No.7
4
Step 1. Thread the assembled Y axis into the main frame(A1), put the main frame between the Connecting fender and the M10 nut. The Connecting fender is at the front part of the Y axis. Step 2. Connect the side panel to the rear support plate, screw it up with M3 x 16mm screw and M3 square nut. Step 3. Fix the connecting fender to A1 with M3 x 20mm screw and M3 hex nut.
12.Fan mount
M3 x 25mm screw
No. 25
4
M3 hex nut
No. 2
4
Fan
No.56
1
Mount the fan on the left side of the A1. Watch the video here.
Step 1. Mount the Z-axis nut.
M3 x 16mm screw
No. 23
4
M3 washer
No. 7
4
Z-axis nut
No.17
1
Left bearing bottom plate
No.A18
1
Mount the Z nut on the A 18 from bottom to up, fix with M3 x 16mm screw and M3 washer.
M3 x 30mm screw
No. 26
2
M3 x 50 screw
No.28
1
M3 hex nut
No. 12/center>
4
Spring
No.34
1
Endstop holder
No.A21
1
Endstop holder
No.A22
1
Step 3. Mount the endstop
M2.5 x 16mm screw
No. 20
2
M2.5 hex nut
No. 11
2
End stop
No.52/center>
1
Left bearing top plate
No.A17
1
M3 x 16mm screw
No. 23
8
M3 Square nut
No. 16
8
X motor holder
No.A 16/center>
1
X axis rod holder (left)
No.A 19
2
X axis belt holder
No.A 20
1
  • Note the direction
No. 37
1
M4x16mm screw
No. 30
4
M3 x 16mm screw
No. 23/center>
4
M3 Square nut
No. 16
4
M3 x 16mm screw
No. 23
4
M3 washer
No. 7
4
Z-axis nut
No.17/center>
1
Right bearing top/bottom plate
No.A24
1
M3 x 16mm screw
No. 23
4
M3 Square nut
No. 16
4
Right bearing holder
No.A23
1
X axis rod holder(right)
No.A25
1
X axis driving wheel support holder
No.A26
1
M3 x 16mm screw
No. 23
4
M3 Square nut
No. 16
4
No.A23
1
No. 37
1
M4x16mm screw
No. 30
4
stepper motor
No.63
3
M3 x12mm screw
No.22
12
Pulley
No.42
1
Mount the X motor
Mount the Z motor
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
10
M3x12mm screw
No.22
2
M3 hex nut
No.12
2
belt mount
No.41
1
X axis bearing support plate
No.A 29
1
Extruder Bracket
No.A30
1
extruder bracket support
No.A31
2
SCS8UU Linear Bearing
No.36
3
M4x16mm screw
No. 30
12
Extruder
No. 61
1
M4x12mm Screw
No.29
1
17. X belt driving wheel
Driven wheel holder
No.40
1
624zz Ball Bearing
No.35
2
M3 x50mm screw
No.28
3
M4 x 25mm screw
No.31
2
M4 locking nut
No.16
2
wing nut
No.42
1
L430mm smooth rod
No.2
2
locking ring
No.35
2
X axis Fender
No.A27
2
Add the belt
Timing belt
No.39
1
M3 x8mm screw
No.21
1
M3 washer
No.7
1
500px
  • Tips:
19. Assemble the X axis on the printer
L322mm smooth rod
No.1
2
300mm threaded rod
No.4
2
Coupling
No.38
2
Z top mount
No.A8
2
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
locking ring
No.32
2
Building platform
No.44
1
Heatbed set
No.53,54,55
1
wing nut
No.42
4
Hex Counter-sunk-head screw
No.19
4
Spring
No.33
4
23.Mount the LCD panel
LCD 2004
No.64
1
Knob
No.65
1
Spacer
No.50
4
M3 x 12mm screw
No.22
4
EXP 1 is for the SD card reader. EXP 2 is for the displaying of the LCD.
Do not mix them up.
Here you can watch the video.
Power supply Unit
No.58
1
3D Power Cable
No.60
1
M3 x 12mm screw
No.22
4
No.18
2
M3 hex nut
No. 2
2
25.Mount the control board.
Control board kit
No.62
1
Sticker
No.47
1
Heat sink
No.48
1
Spacer
No.50
4
M3 x 12mm screw
No.22
4
Here is the video.
26.Wiring
GT2560 Before you start wiring, please take a look at the wiring schematics.
File:15 y motor1.jpg
File:15 z motor1.jpg
4) Connect Extruder motors
Connect extruder 1.
Step4. Connect heating wires.
Step7. Connect wires for Fan.
EXP1 to SD card
EXP2 to LCD
Brown------L
Blue ------N
Yellow------GND
Red ------ -- + V
Black------COM
27.Mount the filament spool.
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Spool base plate
1
Spool side pane
2
PVC tube
1
PVC tube
2
Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed.  Frame is stable and correctly aligned.  Belts are taut.  Bed is level in relation to the path of the extruder.  Filament rolls freely from the spool, without causing too much tension on the extruder.
Current for stepper motors is set to the correct level.
Firmware settings are correct including: axis movement speeds and acceleration; temperature control; end-stops; motor directions.
Extruder is calibrated in the firmware with the correct steps per mm of filament.
The point regarding the extruder step rate is vital. Slic3r expects that the machine will accurately produce a set amount of filament when told to do so. Too much will result in blobs and other imperfections in the print. Too little will result in gaps and poor inter-layer adhesion. For how to set up the printer, please visit:https://www.youtube.com/playlist?list=PLODCkot3GriiNbAxIwO9JCZjQSb92CWN7
