Geeetech prusa i3 pro C building instruction
Revision as of 03:32, 8 June 2015 by Admin (talk | contribs) (→Step4)
Notice:
Unfold and check the package
Tips:
Assemble the rods of a Y axis
M10 threaded rod
2
NO.5
Y plate connecting plate
2
NO.A14
M8 spring washer
6
NO.18
M10 washer
8
NO.9
M10 nut
8
NO.12
M8 smooth rod
2
NO.3
LM8UU Linear bearings
4
NO.39
Acrylic plate(front)
2
NO.A9,A10
Acrylic plate(back)
2
NO.A11,A12
M10 washer
4
NO.9
M10 nut
4
NO.12
Assemble the Y idler
624ZZ Ball bearing
2
NO.38
bearing holder
1
NO.66
M3 x20 screw
1
NO.27
M3 wing nut
1
NO.15
M3 x25 screw
1
NO.35
M4 lock nut
1
NO.14
Mount the Y motor
Y motor fix plate
1
NO.A13
Stepper motor
1
NO.75
pulley
1
NO.43
M3 x12 screw
3
NO.25
M3 x16 screw
2
NO.26
M3 square nut
2
NO.16
Build the printing platform
Y platform support
1
NO.A15
Y bearing block
4
NO.A16
Y belt mount
1
NO.67
Zip tie
4
NO.54
M3 x10 screw
2
NO.24
M3 x20 screw
8
NO.27
M3 nut
8
NO.11
Step4. Mount the belt.
Timing belt
1
NO.41
M3 x10 screw
2
NO.24
M3 washer
2
NO.7
Assemble Y - Z axis
X-Z frame
1
NO.A1
Acrylic fender
2
NO.A12
M3 x20 screw
4
NO.27
M3 nut
4
NO.11
Mount the fan
Fan
1
NO.71
M3 x30 screw
4
NO.28
M3 lock nut
4
NO.13
Acrylic left panel
1
NO.A2
Acrylic right panel
1
NO.A3
M3 x16 screw
8
NO.26
M3 square nut
8
NO.16
Z Motor fixed plate
2
NO.A4,A5
Z Motor support plate
4
NO.A6,A7
M3 x16 screw
10
NO.26
M3 square nut
10
NO.16
Assemble the 2 Z motors
Stepper Motor
2
NO.75
M3 x12 screw
8
NO.25
Assemble the smooth rods
370mm smooth rod
2
NO.2
LM8UU linear bearing
2
NO.40
624ZZ Ball bearing
2
NO.38
Bearing holder
1
NO.66
M3 X30 screw
1
NO.28
M4 X25 screw
1
NO.35
M4 locknut
1
NO.14
Assemble the X-Axis end
X-axis left end
1
NO.P1
X-axis right end
1
NO.P2
2
NO.40
M3 X16 screw
2
NO.26
M3 wing nut
2
NO.15
M3 nut
2
NO.11
Brass nut
2
NO.17
M3 x 16 screw
8
NO.26
M3 x50 screw
1
NO.31
M3 nut
1
NO.11
Screw locking ring
2
NO.19
print bracket
1
NO.P3
Zip tie
4
NO.54
2
NO.40
Mount the extruder holder
Extruder bracket
1
NO.P4
M4 x16 screw
2
NO.34
M4 nut
2
NO.11A
Mount the extruder
MK8 dual extruder
1
NO.79
M4 x12 screw
2
NO.34
M4 nut
2
NO.11A
mount the fan for extruder
fan
1
NO.70
M3 x30 screw
2
NO.28
M3 washer
2
NO.7
Mount the X-axis motor
Stepper motor
1
NO.75
Pulley
1
NO.43
M3 x8 screw
3
NO.23
Amount the X-axis belt
Belt
1
NO.42
Zip tie
2
NO.54
Assemble the X-Z axis
L322 threaded rod
2
NO.4
Couplings
2
NO.69
Z-axis top mount
2
NO.A8
M3 x16 screw
4
NO.26
M3 square nut
4
NO.16
Attach he heated bed
MK2A Heat bed
1
NO.71
Borosilicate glass
1
NO.72
Heating wire
2
NO.51
Thermistor
1
Attached on the bed
Thermometry wire
2
NO.50
Wing nut
4
NO.15
Spring
4
NO.37
M3 x35 screw
4
NO.29
clamp
4
NO.53
Mount the end stops
Step 1.End stop of X-axis
End stop
1
NO.44
M2.5 x12 screw
2
NO.21
Step2. End stop of Y-axis
End stop
1
NO.45
M2.5 x16 screw
2
NO.22
M2.5 square nut
2
NO.10
Step3. End stop of Z-axis
End stop
1
NO.46
M3 x16 screw
2
NO.22
M3 nut
2
NO.11
Mount the LCD panel frame
LCD 2004
1
NO.80
LCD frame
1
NO.A21
LCD frame holder
2
NO.A23
Acrylic washer
4
NO.A20
M3 x20 screw
6
NO.27
M3 nut
4
NO.11
Mount the PSU
PSU
1
NO.74
M3 x10 screw
3
NO.24
M3 x16 bolt
2
NO.36
M3 nut
2
NO.11
3D Power cable
1
NO.52
There is one thing you need to note that the extruder number in this picture is 1 and 2, but in the following steps, I referred them as 0 and 1 correspondingly.
Step1
Step2
Plug the 5 A4988 into the stepper motor driver slot. Mind the directions of A4988. (It is recommended wear static gloves when plugging A4988)
Step3
Connect wires for motors.
Here you need to use the DuPont wire (NO.64).
Plug the end with one terminal into the Z motor slot. And connect the two wires of Z motor to the two DuPont wires separately.
Note the color of the connection as below:
DuPont wires Motor wire!
Red
Blue
Black
Red
Blue
Green
Purple
Black
4) Connect Extruders
As you can see 0 and 1 from the extruder holder [NO.P4], you need to straighten out the two wires and do not mix them up.
Connect extruder 0.
Connect extruder 1.
Step4
Connect heating wires.
2) Connect heating wires for extruder 0.
3) Connect heating wires for extruder 1.
Step5
Connect wires for thermistor.
3) Connect wires for thermistor of extruder 1.
Step6
Connect wires for endstop.
* There is no “+” and “-“for endstop
1) Connect wires for endstop of X-axis at X-MIN.
2) Connect wires for endstop of Y-axis at Y-MIN.
3) Connect wires for endstop of Z-axis at Z-MIN.
Step7
Connect wires for Fan.
Note the “+” and “-“for fan
Red: +
Black: -
Step8
Connect wires for LCD panel.
Step9
Connect wires for power input.
mount the board
Mount the board on the left side panel of the printer. And cover the board with the acrylic plate.
Spacer
4
NO.48
zip tiew
2
NO.54
As there is no location hole for GT2560 for the moment, you can use zip ties to fix the board or you can use foam glue if you have. Please pay attention to the direction of the board, the end with Capacitor should be mounted towards the fan for better heat dissipation.
Mount the filament spool
Filament side panel
3
NO.A17,18
M3 x16 screw
4
NO.26
M3 square nut
4
NO.16
PVC tube
2
NO.60,61
