Delta Rostock mini G2 Building Instruction
Preparation
Chapter1 Base Assembly
Motor end assembly
Mount the LCD panel
Mount the fan
Mount the control board.
The directions of the spacer are as the arrow showing.
Mount the print bed.
Chapter 2 Top Plate Assembly
endstop mount
Drive wheel mount
Mount the extruder
Find out the locating holes on the top plate; screw up the extruder with 4 M5 x 16 screws and washers.
The screws are bottom - up.
Mount the spool holder
Screw up the spool holder panel on the top plate separately with M3X16 screw and M3 nut and washer.
Chapter3 mount the smooth rods
Assemble the spider
Step1. Stack the hotend bracket and half bracket together, screw up with 4 M3 x 16 screws and M3 nut.
Insert the hotend into the gap of the bracket.
(Note: For your convenience, the hotend is assembled with heaters and sensors, so, please ignore the difference in the picture) .
