Iduino Yun Shield
- Low power consumption
Overview and Hard ware Resources
front side -
back side
- Processor: 400MHz, 24 MIPS
- Flash: 16MB
- RAM: 64MB
- 1×10M/100M RJ45
- External antenna via I-Pex
- 1×Reset button
Size: 70mm * 53mm*24mm
Weight: 33.2g
Software Resource
Source
Interface layout
Interface layout -
wireframe
Interface specifications
Getting IP address
Factory IP of Wifi port
FallBack IP
If the user’s laptop IP is
Detect IP from Arduino IDE
Allocation pattern
Webpage access
SSH Access
SSH Access:
- Port: 22
- User Name: root
- Password: iduino (default)
Webpage Setting
General setting
Settings of Iduino
Upgrade
Use with Arduino Board
- Whether the Arduino board is powered by DC jack;
- If the board type setting is correct in the Iduino_Yun_Shield;
- If the board type setting is correct in the Arduino IDE;
- Make sure the UART mode is in Arduino Bridge.
Connect to Arduino Board
Connect to Leonardo
Connect to Arduino Uno
Connect to Arduino Mega2560
Detect Iduino_Yun_Shield
Upload Sketch
Example
Say hello to Linux
Code:
String name;
voidsetup() {
Bridge.begin();
Console.begin();
while (!Console);
void loop() {
if (c == '\n') {
Console.print("Hi ");
Console.print(name);
Console.println();
name = ""; // clear the name string
Else { // if the buffer is empty Cosole.read() returns -1
Test Interface:
In Hardware Aspect
In Software Aspect
- If the Iduino_Yun_Shield boots in advance than Arduino IDE, this situation may happen. So try to reboot the Iduino_Yun_Shield and check again.
- User name: root
- Protocol: SCP
How to reset Iduino_Yun_Shield?
- If pressing the toggle button and release after 5 seconds, it will reset the Wifi setting and other settings will be kept.
- If pressing the toggle button and release after 30 seconds, it will reset all the settings to factory default.
5.Set TPFP service:
- (2)Host: 192.168.255.2
- Port:6666
- Port:6666
- Module IP: 192.168.255.1
- Port: 6666
- Local Port: 6666
14.Choose ,font color="blue">root-squashfs file
reset<CR>
Relevant file:
Reset to the new firmware
Reset
How to get it
