PIXHAWK
PIXHAWK is an advanced autopilot system of 3DR. It features transparent for hardware and convenient for re-development. PIXHAWK integrates with two advanced processor, STM32F103 backup failsafe 32-bit co-processor provides for manual recovery and has its own power supply if one processor breaks down, delivering incredible performance, flexibility, and reliability for controlling any autonomous vehicle. Users can also adjust the configurations of PIXHAWK according to different use and hobbies for different vehicles. In recent years, as one of the cores of autopilot system, PIXHAWK has gained a profound popularity among developers and hobbyists for being practical, easy to handle, economical.
- Advanced 32 bit ARM Cortex® M4 Processor running NuttX RTOS (68 MHz / 252 MIPS Cortex-M4F) real-time operating system.
- 14 PWM/servo outputs (8 with failsafe and manual override, 6 auxiliary, high-power compatible)
- Abundant connectivity options for additional peripherals (UART, I2C, CAN)
- Integrated backup system for in-flight recovery and manual override with dedicated processor and stand-alone power supply
- Backup system integrates mixing, providing consistent autopilot and manual override mixing modes
- Redundant power supply inputs and automatic failover
- External safety button for easy motor activation
- Multicolor LED indicator
- micro-SD card for long-time high-rate logging
Dimension: 81.5 mm*50mm*15.5mm Net weight: 38.4g
Specifications 3 Microprocessors: 32-bit STM32F427 Cortex M4 core with FPU 168 MHz/256 KB RAM/2 MB Flash 32 bit STM32F103 failsafe co-processor
4 Sensors: ST Micro L3GD20 3-axis 16-bit gyroscope ST Micro LSM303D 3-axis 14-bit accelerometer / magnetometer Invensense MPU 6000 3-axis accelerometer/gyroscope MEAS MS5611 barometer 10 Interfaces: 5x UART (serial ports), one high-power capable, 2x with HW flow control 2x CAN Spektrum DSM / DSM2 / DSM-X® Satellite compatible input up to DX8 (DX9 and above not supported) Futaba S.BUS® compatible input and output PPM sum signal RSSI (PWM or voltage) input I2C® SPI 3.3 and 6.6V ADC inputs External micro-USB port
Power System: Ideal diode controller with automatic failover Servo rail high-power (7 V) and high-current ready All peripheral outputs over-current protected, all inputs ESD protected
