Iduino Yun Shield
- Low power consumption
Overview and Hard ware Resources
front side -
back side
1. Processor: 400MHz, 24 MIPS
2. Flash: 16MB
3. RAM: 64MB
4. Power input: 4.75V~23V via Arduino Vin pin
5. 1×10M/100M RJ45
6. Connector 150M Wifi 802.11 b/g/n
7. External antenna via I-Pex
8. 1×USB port for USB storage or 3G connection
9. 1×Reset button
10. Compatible with 3.3V or 5V I/O Arduino
Size: 70mm * 53mm*24mm
Weight: 33.2g
Software Resource
Source
Interface
Interface layout
Interface layout -
wireframe
Interface specifications
Getting IP address
Factory IP of Wifi port
FallBack IP
Allocation pattern
Webpage access
SSH Access
SSH Access:
- Port: 22
- User Name: root
- Password: iduino (default)
Webpage Setting
General setting
Settings of Iduino
Arduino board Type: Define the setting of bootloader/mcu type/fuse during Sketch uploading Operation Mode: Make sure the mode is Arduino Bridge mode so that the Bridge class can work
Upgrade
Use with Arduino Board
1.Whether the Arduino board is powered by DC jack;
2.If the board type setting is correct in the Iduino_Yun_Shield;
3.If the board type setting is correct in the Arduino IDE;
4.Whether the Arduino SPI and UART is not influenced by other hardware
5.Make sure the UART mode is in Arduino Bridge.
Connect to Arduino Board
Connect to Leonardo
Connect to Arduino Uno
