Iduino Yun Shield
- Low power consumption
Overview and Hard ware Resources
front side -
back side
1. Processor: 400MHz, 24 MIPS
2. Flash: 16MB
3. RAM: 64MB
4. Power input: 4.75V~23V via Arduino Vin pin
5. 1×10M/100M RJ45
6. Connector 150M Wifi 802.11 b/g/n
7. External antenna via I-Pex
8. 1×USB port for USB storage or 3G connection
9. 1×Reset button
10. Compatible with 3.3V or 5V I/O Arduino
Size: 70mm * 53mm*24mm
Weight: 33.2g
Software Resource
Source
Interface
Interface layout
Interface layout -
wireframe
Interface specifications
Getting IP address
Factory IP of Wifi port
FallBack IP
Allocation pattern
Webpage access
SSH Access
