HM-TRLR-S Series 100mW LoRa Transceiver
Revision as of 06:48, 22 October 2014 by Admin (talk | contribs) (→Parameters)
HM-TRLR-S series is a low cost, high performance transparent transceiver operating at 433/915MHz. It is LoRa/FSK/GFSK/OOK modulation variety. It features small size, high output power, high sensitivity, long transmission distance and most of the parameters can be set via the command. Receive and send data to automatically switch. Use generic UART interface. It is easy to realize the wireless data transmission if provided with the UART data. It is flexible for the users to set the parameters of UART baud rate, output power, data rate, frequency select, modulation mode select etc. It is your ideal choice for designing wireless data transmission products which can be widely used on wireless data transmission field.
  • Low cost, high performance, high reliability
  • LoRa/FSK/GFSK/OOK modulation, 2-way half –duplex communication, strong anti-interfere
  • 433/915MHz ISM band, globally license free.
  • Maximal output power100mW(20dBm), output power adjustable between 2-20dBm
  • LORA Sensitivity -139dBm
  • Supply current for Tx 130mA@20dBm, 35mA@13dBm
  • Supply current for Rx 16mA
  • Low current sleep mode 2uA
  • Standard UART interface, extendable to RS232 or other interface
  • Operation frequency can be configured, acceptable for several modules working in different frequency with no disturbance on each other.
  • RF parameters as needed, users can be modulated by software.
  • Easily use, auto exchange on communication & transceiver
  • Communication speed 1.2kbps -115.2kbps,can be modulated through software
  • Afford Sleep control signal,user self control work duty cycle
  • With LED indicator
  • Longer transmission distance,over 5Km in open air
  • Small size 16*20*2mm,10PIN SMD package,easy for assembly .
  • Tuning free
  • Accord FCC, ETSI standard
Applications
  • Remote control, remote measurement
  • Data collection
  • Wireless meter
  • Access control
  • IT household appliance
  • Intelligence household appliance
  • Identification system
Pin Description
VCC—— Power supply,2.4-3.6V DC power, recommendation 3.3V DC power
TXD—— Data transmission
GND—— Ground
RXD—— Data receiving
CONFIG——Set low for configuration mode, while set high for communication
SLEEP——Set low for normal mode for data transceiver , while back to sleep if set high
STATUS——Disconnected
RESET——Reset trigger input, Active low
ANT—— Input/output interface with 50 ohm antenna
GND—— Ground
Maximum Specification
Parameters
